IanD
Sweet spot refers to the middle portion of the lens which is forming the image on the smaller target. The outer part of the image circle which normally exhibits the falloff of resolution and light, is cropped out. This alone is not ample reason to invest in medium format optics, but remains an advantage nonetheless.
As to multiplication factor: A 75mm is a 75mm no matter what format is used. All that changes is FOV. There's no multiplication issue to deal with. A 75mm lens for medium format, when used on a 35mm camera for example, has the same magnification as a 75mm lens designed for 35mm used on a 35mm camera.
Know what I mean?
Know what I mean?
