I've been looking for wide angle lens for the M2 because I loose so much space when I use the M2. But they are expensive and they aren't as fast as the 50mm lens......
However, I just realized today that I really don't need a wide angle lens!!!
because if I take off the adapter, the camera will have plenty of room to shoot wide angle shoots, right!!!
I know I won't have Shallow depth of field but even if I had a wide angle lens on the M2, the focal point is very short so I would have to focus to infinty anyway....
which means I won't have Shallow depth of field even when I'm using a wide angle lens correct?
also for telephot shots it's the same!!
if I take the M2 off and just use the zoom on the camera, I am zooming in so I will automaticly have Shallow depth of field even without the M2!!!!!
I just thought about this today so I'm not sure if it works 100% on all shots but I think this will save so much money (I mean, a lot of $$$$$$$$$$$)
has anyone done this???
Or is there something special if I use a wide/telephot lens on the M2 ?
