Press release: new 17" 1760 monitor
Barry_Green
Moderator
news
FOR IMMEDIATE RELEASE
PANASONIC ANNOUNCES CRT PERFORMANCE IN ​
A NEW 17” LCD PRODUCTION MONITOR ​
*120 Hz. BT-LH1760 Features Stunning Picture Quality * ​
SECAUCUS, NJ (February 13, 2008) – Panasonic announced a revolutionary enhancement in the performance of high-quality production LCD monitors – the 120Hz 17” BT-LH1760. The new monitor offers wide off-axis viewing and color reproduction, and provides the motion handling and latency advantages formerly provided only in CRT monitors. The LH1760 is a widescreen high definition display that delivers impressive color reproduction and now offers a vectorscope function in addition to Panasonic’s standard built-in waveform monitoring function.
Utilizing a newIn-Plane Switching (IPS) panel with 1280 x 768-pixel native resolution, the LH1760 produces faithful color reproduction with twice the response speed of other currently available professional LCD monitors, so images appear crystal clear, precise and true-to-life, even when displaying fast motion content.
The LH1760 features a 120Hz refresh rate*, double that of standard 60Hz LCD monitors. This enables the monitor to handle fast motion content exceptionally well, minimizing image blur to a level never before seen in a professional LCD display.
In addition, this high performance production monitor is equipped with a built-in waveform monitor and vectorscope that display all picture lines for signal level monitoring. For critical HD focusing and comparison, the LH1760 comes with valuablefunctions such as Pixel-to-Pixel matching, which allows the user to see an input signal pixel by pixel without any resizing, and Split Screen/Freeze Frame (live input vs. freeze frame).
The LH1760 features an array of input/outputs to support virtually any production task including DVI-D input, two auto-switching HD-SDI/SDI inputs, component video (Y/Pb/Pr), RGB, PC RGB, external sync, speaker and headphone outputs. Additional standard features include embedded audio, time code, closed caption, and an eight-channel audio level meter (via SDI).
Inheriting the rugged design of Panasonic’s line of production-tough monitors, the rack-mountable
LH1760 is thin, lightweight and durable, with a die-cast aluminum build. The compact monitor has low energy consumption and, because there is no need for a fan, offers quiet operation.
The LH1760 will be available in April 2008 at a suggested list price under $5,000.
The high-performance LH1760 joins Panasonic’s BT family of production LCD monitors, which includes the 7.9” BT-LH80W, 8.4” BT-LH900A, 17” BT-LH1700W and 26” BT-LH2600W models.
About Panasonic Broadcast
Panasonic Broadcast & Television Systems Co. is a leading supplier of broadcast and professional video products and systems. Panasonic Broadcast is a unit company of Panasonic Corporation of North
America. The company is the North American headquarters of Matsushita Electric Industrial Co., Ltd. (NYSE: MC) of Japan, and the hub of its U.S. marketing, sales, service and R&D operations. For more information on Panasonic Broadcast products, access the company’s web site at www.panasonic.com/broadcast.
* The refresh rate is the number of times per second an image signal is illuminated on a display.
- 30 -
EDITORIAL CONTACTS:
Stacy Moore or Pat Lamb
(201) 392-4458 (518) 692-8150
moorest@us.panasonic.compatalamb@aol.com
Hi Barry, i have a question, i'd like to know if the BT-LH1700W could show the wave form from RGB inputs YPbPr?, or is it just composite?
Thanks Barry, we have a HVX200, with an Ikan V8000 on-board, my DP ask me for a WF monitor and i've been thinking about BT-LH1700W. But in OM, Said: This screen in not displayed when "RGB COMP." is selected in the "YPbPr/RGB" menu in the "INPUT SELECT" menu.
