The package I'm using is an HVX-200 with a Cinevate Brevis35, Nokia primes and a Cartoni Focus head with stage one legs.
hahaha "Nokia" I'm sure he meant "Nikons" funny how the mind works.![]()
mcvideo,
I'm not sure about the 4000pro setup. How much weight does it let you carry at the bottom of the sled?
Luis
Still a little unclear as to the specs on the Glidecam 4000. I believe they state that they support 4-10lbs. cameras. that means that they should have 2-6lbs below or so. My monitor is about 3.2lb without battery. with batteries it should be another lb. or so. I'm guessing it should work.
Where are you located. if you are in LA, we can test it out at my place?
Of course I want your business, but I don't want to say yes if I haven't tried it. I can tell you it works with my system just fine.
