I have all the required presets and everything to run my 24f footage properly in CS3, but is it normal that as soon as i drag it into the timeline, that i have to render it? It goes red right away? Is this normal?
look down in the bottom right corner, is there a blue bar (progress bar) telling you "conforming"? if so, just wait that one out. should be good after that. First it will do the video then it will do the audio.
now you shouldn't have to render it to edit it. i never render any of my footage while editing. the only reason to render is to see an effect in real time.
??? don't know what to tell you.. I just did some test 24f footage and it came out just fine. i do get that "un rendered" line above my footage but i can edit all i want.
a quick update, i went back to my Premiere 2.0 and noticed that the .avi files (captures from my old Canon GL2) didn't have a render bar. but new footage i dropped on a sequence (newly captured HDV off my Canon XH-A1) comes up with the render bar. it's got to deal with the mpeg format... haven't researched yet, but that's my thought.
As far as i can tell it's a new 3.0 feature. The old 2.0 would only show a red render bar if you had an effect on that video. Now it's the entire video fresh into a sequence.
