Letus Extreme : Canon XH A1 : Glidecam
I'm not using any weights on the top sled, only the bottom.
i believe i have, on EAch side of the bottom plate, one of the top plate weights for lighter cameras, and then 8 round washer weights. so 16 washer weights and 2 of the top plate weights to counter my canon XH A1 with the letus extreme and 24mm lens.
I can take a photo of it if you would like?
Please do that'd be awesome.
here is my baseplate setup
This supports the Canon XH A1 with large battery and tape, with a uv filter, then letus extreme, with cinevate rails, 24mm lens.
Thanks for the pictures and the specifics. I think Glidecam recommends a total weight for the 4000Pro of 18 lbs. That is if your rig weighs under that, add the plates until you reach near 18 lbs.
that sounds about right. I just didnt understand the 5-11 pound statement. Because i could easily add more weight, AND i have a good foot more of piping that can be extended from the shaft..
I think he said he didn't change focus. He used a 24mm, followed the waitress (in focus), and brought the stage into focus as he moved forward.
i should get my LEX and planing to use it with my varizoom navigator, indifocus rails and FF, we will see, how will i succeed in focusing during movement...
Remote follow focus. If you touch your ff while flying, of course you defeat the purpose of the steadicam.
i know... i will have to be flying somewhere around the same distance, get focused then fly again... we'll see if this will or won't work in practice...
