Maybe model the ground floor first.
The upper levels are usually just rows & layers of windows.
For that maybe model one area around a window with the ledge ect. Clone that several times until you have one floor. Then clone each floor and stack them up. You could hand clone them or use a matrix or mograph.
Later you could go back & put a couple lights in some random windows.
//Can you show a photo of a building you had in mind?
Here are several tutorials on creating buildings & city blocks to get started.
Those techniques can be expanded upon as you need more detail.
Included are instruction pdfs and project file downnloads.
How to Create City Blocks
Camera Animation through a City
Close up Detailed Building for Camera Close-up
Creating Detailed Buildings for City Scene
source & more C4D tutorials...
http://www.maxoncomputer.com/tutorial_search.asp
No problemo.
Here's a very simple one I just did in about 1/2 hour using your photograph.
I used the photo as a texture on a cube.
Then used the Mograph cloner with a Random Effector to vary the heights.
Then used a paint program to adjust the color.
If I used a detailed model, or several and did some compositing, well you get the idea. I'll have to try another one.
//If you have mograph and would like this scene file, left me know and I'll upload it somewhere.
But I think those tutorials will be fine.
I sent a PM.
Those tutes are a little old so some things in C4D have been changed since then.
Not bad for your first attempt, I'd play with your lighting and settings a little bit more. Now you've got me wanting to try....![]()
