xray
Wendt x3 or SD Mixpre audiomixer?
Hi, I need a mixer to improve audio recordings, but reading all the difficulties with the low (cold) line-in on the Canon XHA1, I started without one. In Europe the USA mixers are expensive, but I can go with (new) Wendt X3 that is only 200 Euro more than the SD Mixpre. But how I search on the net...you all use the SD 302! It's hard to find useful info on the Wendt.
- one man band !
- Canon XHA1
- AKG C480 B /CK63 ULS/ CK69 ULS / Sennheiser G2 set met MKE2, MKE2 PC (with xlr module)
- also need a working set for high mountaineering (low weight/bulk & can not load batteries)
- Canon HV20 with WA adapter (I was planning on using the G2 set without Beachtek or mixer here)
I try not to buy things I only can use for one camcorder or with one person.
Who is working with the Wendt X3? And has experienced it with the A1? (Used manual mode see Max 2. )
AUDIO on XHA1:
-10 dBV /47 kohms
XLR: XLR jack (pin1: shield, pin2: hot, pin3: cold), ATT: 20 dB
-59.5 dBV (Auto mode)/600 ohms (LINE/MIC switch set to MIC)
6 dBV (Auto mode)/10 kohms (LINE/MIC switch set to LINE)
Max 1: -71.5 dBV (Auto mode, XLR GAIN UP at 12 dB)
Max 2: -71.5 dBV (Manual mode, max. volume)
Max 3: -83.5 dBV (Manual mode, max. volume, XLR GAIN UP at 12 dB)
- one man band !
- Canon XHA1
AUDIO on XHA1:
-10 dBV /47 kohms
