DArcyFD
this is a very unique post - i will pose a problem, then, hey presto, solve it myself!
Problem:
you ever been working with a massive sequence in FCP with lots and lots of audio tracks? ie. about 6+ tracks mixed together at some points? have you ever had FCP, for no apparent reason, suddenly play back one of the tracks incorrectly - it plays a completely different part of the file that that particular audio clip comes from (without you doing anything to it)?
i know it sounds confusing, so here's an example:
in your mix, one of the tracks is a 3min song. you've carefully trimmed it down to a clip that is just the first chorus. it plays back fine as you continue to build up the sequence, but then out of the blue, that exact same clip starts playing the second verse, or the bridge, or the outro.... whatever, it's just a completely different part of the track, despite the fact it hasn't changed at all, even in appearance (ie. the waveforms are exactly as they should be).
now, i've had this happen to me on more than one occasion, always when working with large mixes. the f***ed up thing is that it has happened to me when i've exported something and, burnt out by the mammoth project, have failed to notice this glitch (which is typically only a second or two) until it has been presented to an audience.
Solution:
[you may already know this, or the answer appears 'obvious' to you - great, but there's no need for you to point it out in a 'no sh*t dumba**' way. really, there are better ways to boost your self-esteem. ok i know i'm getting defensive for no reason.]
1. control-click the offending clip, and select 'Reconnect Media...' from the menu.
2. the 'Reconnect Files' box will show you the correct file, but the 'Connect' button will be disabled.
3. click 'Locate' and select the exact same file; click 'OK'.
4. now click 'Connect,' which will be enabled.
the clip should now play back exactly as it did before.
so why am i writing this since i solved my own problem? because i only discovered the solution after nearly flying into a fit of rage, slaving over a hot FCP sequence to meet a swift deadline, and juggling a complicated audio mix. in emoticon terms, i was kinda like :crybaby: :crybaby: :angry: :angry:
rogar-BlackEye(DBG:angry: :crybaby: :badputer:
maybe no one else has ever had this problem. maybe it's the hidden price one pays for using software that's not strictly 'legitimate' .............:undecided maybe i'm really edward norton and brad pitt's a figment of my imagination and bruce willis was dead the whole time.......
anyways i just thought i'd post this here because if i help ONE poor lost soul who came as close to the brink of despair as i did, then it's all worth it.
ps. oh, i just realised my pretentious herzog signature quote just became relevant in a poetic kinda way!
Problem:
Solution:
