marco0782
Marco your statement is totally baseless. Dennis already answer the DOF statement, so I am only going to answer the above statement.
Wow, you don't have to be a jerk to disagree with someone or have a discussion.
Like Barry previously said unless Dennis came up with an innovating new system that actually produces gain rather than light loss, that would be an impossibility.
Here are the facts I know, based on shooting 15+ short films and a feature with the Brevis:
1) The Brevis does not handle light loss the same as other adapters; each stop you go down on the lens does not reduce light transmission by equivalent stops
2) The Brevis with CF1 renders less bokeh at f/1.4 than the other adapters, similar to what the Redrock/SGpro/Letus render at f/2.8
3) This means that more appears in focus at a given f-stop than with the other adapters
4) And in conclusion, means that pulling focus is easy when you shoot wide open on the Brevis and therefore stopping down to assist focus pulling is not as necessary as with other adapters
When I shoot with the SGpro I find it necessary to stop down to f/2.8 when I need to make things easier on the focus puller. With the Brevis I could have left it at f/1.4. What this means is that the Brevis, which is already half a stop faster than the SGpro, now has an extra advantage relatively speaking because in the same shooting situation I will lose two extra stops of light in order to get more in focus with the SGpro.
If you don't understand that then you should test both adapters for yourself. It's really upsetting to find myself attacked when I only came on here to share my experiences to those who might find them helpful. And Barry should just put his assumptions on hold until he actually gets to test the Brevis. The characteristics of the way that the Brevis CF1 handles light are different than anything out there and he's just contributing to misinformation and confusion.
