I got my letus rod system today an I must say I am quite disapointed. (Main gripe at the very bottom of post.)
First of all the overall impression is that the overall quality is a few notches below the redrock railsystem which I also own. Basically it looks like reversed engineering of manfrotto/cavision stuff milled in not all that duarble aluminium. tightening the cameraplate for instance does not have the same solid feel of the manfrotto one found on the redrock. Let's just say, you think you've locked it down but then find your camera shiftiting and making you realise you have to use more force on the lock than one would think if you are used to higher quality equipment.
It's a bit flimsy, and the aluminium does not take much abuse. Tighten the screws on the risers a wee bit to hard and they just eat into the aluminium.
It is very impractical with the raisers sticking out at the bottom unless you have it at full height (which also is less than great, due to impractical ballance etc).
Also tightening the different modules of the system on the rails requiers a hex-key, and it is only tightening in the middle of each block, which is impractical in many ways, basically because you have to tighten/untighten both rods at the same time, wheras on redrock/zacuto you have handles on each side of each block making it possible to for instance slide one of the rods back and forth while everything attached on the rods stays in place because the other rod is still tight.
Other than that having the locking mechanism in the middle of each block in stead of two separate ones makes the with of the blocks shrink when you tighten it (at least in the Letus design, not so much in cavision which is similar) so that sliding a non-tightened block all the way in to a tightened one is sometimes difficult because the distance between the rods is slightly narrower near the tightened railblock.
ANYWAY, THE MAIN PROBLEM IS: The rods are not 15mm, they are probably 15,3 or something because none of my cavision and redrock gear fits them. This my friends is just ridiculous...
I really urge anyon who have need for a railssystem to suit a flipped 35 adapter to rather go for some sort of z-riser soulution, or wait and see what Redrock comes out with to match their flipmodule. I regret I didn't.
I hope letus make som sorely needed upgrades on ther rails-design.
Sorry about bad english and typos. I'm hurried and worried
