I have been playing with the idea of building a Fresnel light. There are some challenges to overcome but I think its possible. Obviously a DIY light should not cost as much or more then the real thing so I think the most important thing is to keep the costs down.
One of the most important parts of a Fresnel light is the actual Fresnel lens. I once built a video projector using a page magnifier, which is a plastic Fresnel lens. The plastic can be cut to a circle to mount in front of the light.
Unfortunately the plastic lens can deform due to heat, and render it useless but it has to get pretty damn hot first. I think some well placed ventilation holes, or if necessary a PC case fan to move some air would do great.
Here is a basic idea that I came up with, based on other Fresnel light models. Note that this is not well thought out, or to scale.
Basically the light socket is mounted on a support bar. The support bar is held in place by two rods and slides back by turning the focus control in the back of the light. The center rod is threaded, and it is what pushes the support bar back and forth as its rotated.
Im not sure what to use as a reflector though, but it should not be expensive or difficult to source.
If anybody has any ideas to contribute, would like to hear your thoughts.
