According to all my research, along with many discussions with Richard, a 575 won't do much in direct sunlight. Even a 1200 PAR isn't going to compete that much (especially when you defuse it.) It seems that a 4K is more what you need. Of course, this all depends on how you are using the unit (outside in direct sun vs inside to bring up levels to equal out light coming in windows, etc.)
A PAR has a more efficient reflector than a Fresnel. Therefore, at the same wattage the PAR will produce more light--of course it's not as focusable (you have to switch out PAR lens for different focus.)
Matthew
Matthew:
You are correct. I did a shoot at Disneyland in bright sunlight and we ended up needing a 4k HMI to key with and we used 1200 watt PARs for rim/hairlight. I normally never would shoot in bright daylight but that was what the client wanted to so we did it. A 575 watt HMI will be close to useless in bright daylight. In shade, might function marginally.
If I would have had more time, reflector boards and a butterfly would have worked better but the rigging time is longer and I didn't have the time.
How did you use the sun in that case? Side, front, or helping with the hairlight in the back?
Matthew
Hi:
Sun as key, 4k as fill and two 1200 watt PARs as hair/rim. Looked pretty good, if I do say so myself. We shot all of the footage, then the client "decided to change directions in the video based upon a new Disney dictate that kids don't like to see younger kids in videos, they only want to see tweeners and teens" Whatever.
Why is there such a big price difference in 575w HMI and 575w HMI PAR? And what's the difference between them? How much more throw has the PAR version? Will it be sufficient to compete with the sun?
