marco0782
My friends and I did a pretty intensive test of these two adapters over the weekend. Ultimately we were unable to perform as ambitious of a test as I had promised earlier, but I hope that the results are as useful to you as they were to us.
I will be posting our results in a few different parts. This first part will demonstrate the difference in bokeh quality, sharpness and light loss using these two lenses:
Nikon 50mm AIS f/1.2
Nikon 85mm AIS f/1.4
Both cameras were recording at 1080i/24pa and with neutral scene file settings except Master Ped set to -2, Cinelike V gamma and Cine Matrix.
Note:
Unfortunately when we tested these lenses wide open there was a slight difference in the way exposure was set on the different HVX's, resulting in the SGpro images to be slightly brighter than the Letus (it would have been easier if we were testing both cameras simultaneously, but we only had one copy of each lens). In order to be as consistent as possible, I have only posted the images at f/2.8 and f/5.6.
The point of focus in these images was the ARRI oval logo on the side of the light.
50mm Test
SGpro - Lens at f/2.8, HVX at f/2.0
Letus35 Extreme - Lens at f/2.8, HVX at f/3.4
SGpro - Lens at f/5.6, HVX at f/2.0
Letus 35 Extreme - Lens at f/5.6, HVX at f/2.0
85mm Test
Letus35 Extreme - Lens at f/2.8, HVX at f/2.8
Letus35 Extreme - Lens at f/5.6, HVX at f/2.0
Conclusions
Bokeh:
The SGpro has more defined bokeh circles. Once you stop down on the Letus the circles become more defined, but they still lag behind the SGpro. This ultimately comes down to a matter of preference, but the SGpro's bokeh is more filmlike throughout the aperture range.
Sharpness:
They are both equally sharp to my eyes. If you look closely the Letus appears to have slightly more depth of field which may give the illusion of increased sharpness.
Light loss:
The SGpro loses roughly one stop more light than the Letus, and that is without a flip module.
Coming soon:
Part II will focus on how both adapters perform with high shutter speeds and small apertures.
Note:
50mm Test
85mm Test
Conclusions
Bokeh:
Sharpness:
Light loss:
Coming soon:
