The Brevis is the fastest. It only loses .5 stops WITH a 50mm prime attached, whereas the Letus Extreme loses .5 stops with no lens attached.
would 2.8f zooms work on low light conditions?
I want to get a pair of excellent zooms to cover all lengths but the Ninkon 2.8f's are already out of my budget. How many stops would I lose with them on? And what about the longer lengths where they will lose even more light?
When dealing with prime lenses, yes, the higher the focal length (and lower) the more the lenses tend to become slower and slower. Fast lenses are cheapest around 50mm and either increase in price, or just speed as you move in either focal length direction away.And what about the longer lengths where they will lose even more light?
As far as zoom lenses, some of them are rated with two minimum f-stops. One for the wide zoom focal length, and then a slightly slower one for the maximum zoom focal length. They do make zooms which do not 'darken' when zooming through the range of focal lengths.
Did I make sense?rogar-Shock(DBG):
To clarify this a bit, on lower end zoom lenses you may noticed that the iris will start to close as you zoom in. This is true on the HVX, DVX, A1, XL2 etc.
That's why when looking at zoom lense you see that they give 2 f-stops, like f3.5-f5.6 or something like that. It means that the iris can remain open at f3.5 when you're at the widest end of the zoom range and it will not open more than f5.6 at the telephoto end. More expensive lenses will allow you to have a constant f-stop through the entire zoom range (usually f2.8, I haven't seen any faster lenses; if there is those would cost an arm and a leg).
Hey thanks Ryan, and you did make complete sense. Jade, thanks for adding to it. I understand now... the iris closes as you zoom... I was hoping that would be the case but I was scared to ask.
So let me just ask while I still have you guys here:
_ The camera is the HVX
_ The adapter is the Brevis
_ The lights will be 1000w Kino, 500w Kino, Alzo 800w and Richard's 575 HMI for 1500w in a fresnel
Will these suffice if they turn out to be a matching pair and sharp enough as they seem to be:
http://www.bhphotovideo.com/bnh/con...&A=details&Q=&sku=36956&is=GREY#goto_itemInfo
http://www.bhphotovideo.com/bnh/controller/home?O=WishList.jsp&A=details&Q=&sku=124669&is=GREY
I looked at their F stop rating but couldn't find the open-zoomed F stop, just the one 2.8f listed, then the 2.8f - 22f that you can set it to. On the wide one it seems I might have to set it to about 3f or slightly higher to avoid softness, but I might still be able to get away with 2.8f since we are only shooting 2MP while these are easily used with at least 5MP and higher pro-sumer still bodies given their price and people still think they are sharp enough... maybe not sharp enough for 8MP and higher but hey... that's not an issue for us... right?
Two touch means the focus ring is separate then the zoom ring. Many medium and low cost photography lenses have what's called "push pull" zooms. The focus ring turns normally but can be pushed forward or pulled back for the zoom function. Many people buy these lenses not thinking, and realize the follow focus does not work with it. Not to mention critical focusing is out the window.Could you tell me what is a "two touch"?
Remember the jabber Jade and I were talking about?And when you said "consistent through the focal length", what exactly is it you are saying stays consistent? It can't be focus, or light loss... ?
The lenses you have selected to not have the two f-stops listed meaning it is a 2.8 all the way from widest to longest focal length. This is good because if you are zooming in a shot, you won't have to worry about pulling your exposure as well.To clarify this a bit, on lower end zoom lenses you may noticed that the iris will start to close as you zoom in. This is true on the HVX, DVX, A1, XL2 etc.
