so I guess I really can't get a Zoom unless I plan to spend several thousands on each and probably will need "better" brands. Not that Nikon is bad by any means, but I'd probably have to go with lenses designed for film... and a MUCH bigger budget.
Ok... so I am guessing I will most likely end up with a set of primes... so...
When I look at Nikons... which are the types I can rely on? There seems to be different types which are differentiated by the letters such as "VR"... which are good and which aren't (hope it is that simple)
And how does Pure's list plus a 28mm sound?
28mm (which?)
50mm 1.4 AIS
85mm 1.4 D
105mm 2.8 Micro NonVR D
180mm 2.8
200mm 2.0
What is that gonna cost me?
Zooms are not the sharpest at all but can be useful. I only shoot with primes on my HVX though.
That's a pretty misleading statement. It depends entirely on the quality of the glass. I have two AF-S zooms which are substantially sharper than most of the static glass that they replace. On an HVX, in any case, the lens' sharpness is probably not the limiting factor (unless you're shooting with a $50 Tokina or Tamron or whatever).
