bt_impaler
I've spent a long time reading the forums and trying to determine what route to go with a 35mm lens adapter. For two years I've been holding off buying anything (no money), but now I finally have enough to spend so I upped my research again~ $1500-2000 on this.
My friend has a canon xa h1 and that's what I intend to use it on. Initially, I was leaning towards the M2, but then upon further research I liked the Letus Extreme for its flip capabilities because that way I wouldn't need an external monitor. Then I read further and discovered that without an external monitor you can't pull focus accurately. Also the Letus looked like it needed rails - then I found the Brevis - and that had a nice rail package and modular design (promising a flip unit) which I also like because it's then easily upgradeable.
With this set up, I'm looking to shoot mostly hand-held style short films and, in the future, wedding videos (obviously there's more I'd do, but that's what I'd do most frequently). Because most of what I'd do would be hand-held, I want to avoid a monitor. So, could I get away by going hand-held with the Letus Extreme and that mini support system it comes with to work with my Nikon lenses (28mm f/2, 50mm f/2, 105mm f/2.8) or will I need to get a monitor - and in that case I'd go Brevis.
If I go the brevis route with a monitor, how difficult does hand-held shooting become? Do I need an HD monitor? Is the tote vision HD 7" monitor servicable and can it be mounted upside down? That's it for now. I'm sure with each quesiton answered I'll have two more. Thanks.
Brad
Brad
