Ted Ramasola
Just want to share my results after making a 35mm lens adapter.
I first made the mid format adapter for rb645 lenses, and after using it in some corporate videos and a TVC i decided to fabricate one for 35mm lens.
For the pros and cons.
The mid format adapter cast a bigger gg image at 42mm x 24mm, this is much easier to capture and theoritically a less grainier image.
But other than this i began to encounter its limitations.
The adapter is bigger, due to bigger gg at deeper flange distance.
Limited availability of a variety of lenses not to mention more expensive than 35mm lenses.
I found another source of gg other than a frosted cd and began fabricating a 35mm lens adapter using an extension tube as a mount.
Since the image i am capturing is 29.6mm x 16.6mm on the GG i can use a smaller diameter gg and smaller housing. (see attached pic of size comparison).
The 35mm set up is less forgiving in alignment tolerances. Its really more difficult in getting everything centered and aligned as compared to the mid format.
In the end, the efforts are well worth it.
It aint perfect yet but i found it usable.
I also made a DIY rod system to support the rig and allow it to be used on different cameras, currently using it with hd100.
