Okay, so it sounds like I'll be just fine with a recorder, recording two seperate tracks onto it and doing the mix in post. Good, one less piece of a equipment I have to scrounge up.
What about the lavs? If I lav two people up (which I will have to do in my movie), how do those wireless lavs send signals to my recorder? Do I have to buy compatible equipment? (recorder and lavs) - Or is all that stuff universally compatible?
I don't think I'll need two shotgun mics and two lav mics running at the same time. Unless you're saying to get two recordings of the same scene/actors in case one "feed" is better than the other. It would be nice to have that, but I think I'll be okay with a maximum of two mics running at once. In that case, just getting a recorder, recording two seperate tracks, and then mixing in post should be okay, right?
Also, still a little confused by the lavs. Help me out here. You have a wireless lav mic. You put it on someone. What they say into this mic floats through the air until it gets to..... what? Where is the "receiver" end of this mic? Is it like some little box? And does that box then have an XLR cable connected to it, that then goes into your mixer/recorder?
I am purchasing a Tascam HD-P2 for a feature, we will be using two mics for this so would you recommend it being paired with a mixer? If so can you recommend something under $500, im already spending most of our sound budget on the P2.
