NEW 1024x768 HD Monitor
If you are around DV Expo come by the Redrock booth #102 and check it out. Luis will be there in the early AM on wednesday (at least that's what he tells me :) )
Brian
This is cool, Luis. I'm really looking forward to hearing some first hand feedback from user's of your monitor. Sounds like it could be a very viable alternative to what's out there right now.
Take care,
Jason
So the first day of DV expo is over.
I was just going to stop by and say hi, but I ended hanging around the Redrock booth for a while.
Also talked to a few people that really liked the monitor. Then I went to a few resellers to see if they were interested in seeing the monitor. The guys from Pro HD rentals in burbank are interested in carrying the monitor, so are the guys from EVS in Glendale. And also Coffey Sound might want to carry it.
So far the monitor is a hit. if any one got a chance to stop by, please let me know what you thought.
I will be there tomorrow also. :)
hope to see you there.
Congrats on the offers from retailers!
So what is the difference between the cheaper and more expensive one? I briefly was looking but couldn't figure out the difference in the specs.
That "C" model has a great feature set for the money. Awesome. Is there an Anton Bauer Gold option and / or adapter to PowerTap?
These will be my next two monitors.
USLatin,
The difference in models are just the extra inputs. The A model has all the inputs with Component HD (RGB). Model B has all those inputs Plus 1 HD-SDI in/out. Model C has all those inputs Plus 2 HD-SDI in/out.
Ftbt,
Thanks for the compliment. Yes, I've been getting alot of compliments on it, and many people are excited about getting this quality at such a low price.
Overland,
Yes, there is an Anton Bauer Gold mount, a IDX (sony) V-mount, and dual Panasonic/Sony/Canon mount. The beauty of the Battey plates is that they are replaceable with some thumbscrews (show them at the DV expo to some people. Will have pictures up soon). so you are not stuck with one battery option. you can select your battery plate on the spot.
Oh... thanks.
Question, since I haven't though much about it... why would you want two HD-SDIs? Right?
Would it be for it you used for monitoring of two separate cameras? Neat sorta overkill but for the price difference and given that there is nothing in the same price point at tha monitor's level it would be hard not to go for it.
EDIT:
"The dual link HD interface supports 1080p60, 1080p59.94, and 1080p50, as well as 4:4:4 encoding, greater color depth, RGB encoding, alpha channels, and nonstandard resolutions (often encountered in computer graphics or digital cinema)"
From Wikipedia
Is that the right one? I know too little about this... just now started working on getting a CC monitor for the computer. On-Camera LCD would be next.
Yeah, in case you were using it as a director monitor and you wanted to switch between one and the other. It also has a side by side, so I think you could see each one next to each other, but I would have to double check this. The picture in picture doesn't let you use it with certain input combinations. I don't have HD-SDI outputs so I can't check this. I've tested the HD-SDI input and it looks amazing.
Have you tested the color reproduction? I am not 100% on how this would be done. I am sure it is great for the price, but is there a way to quantify this? Like I said I am just now getting into monitors.
Color reproduction is a tricky thing.
First you have to feed it a good image (which means if you camera is not outputting an image that reproduces the colors right then you won't see that in your monitor)
Then you have to set the monitor to the right settings and calibration.
Then it becomes a subjective issue since everyone's eyes are not the same.
I feel the color reproduction is amazing on it. At DV Expo, we had it set up with a JVC GYHD250 through the HD-SDI input, and it looked incredible. The thing has so many settings that you can dial it in. I usually just set the color bars and then (in analogue RGB mode. doesn't work in HDSDI) I hit the autocolor and it calibrates it pretty close. I then just fine tune it. and I can get color calibration perfect with it.
You'll see it at the DVXuser meeting. :)
Luis,
Thanks for the "floor show" (literally) at DV Expo! The monitor is awesome! Thanks for the demo. We went over to the Marshall booth after your demo and nothing there compares to the features on your monitor. And for the price, can't be beat!
I really appreciate the little details that you have put into this.
Question: What is the warranty that you're offering?
Question: Can this be used as an SD monitor?
Question: Is the price that you're quoting a pre-production price? Show special?
Thank you.
RobertE,
Thanks for the kind words. Yes, my monitor is pretty sweet. I actually was encouraging people to go check out the other booths. (I'm just confident that this monitor is that nice. And at this price, nothing comes close)
Warranty: I'm debating about this. I'm a small fish, so I'm debating between 6 months or the standard 1 year.
In any case these things are build like tanks. The case is 1/16" aluminum all around. (some of the other cases are much thinner.) and everything inside is mounted with tons of screws. So as far as mechanical failures I'm not worried. I'd just hate to have some people mistreat the product and then blame me and require their money back. This would put me out of business.
I am implementing a strick system which will let me know if you open the case or if it has been around moisture. If any of these two have taken place, the warranty will be void.
Just know this, I won't leave you guys stranded if in fact the problems are from the internal components. But please understand that some people break their gear themselves and then try to blame the Manufacturer. This would be bad for all of us, since I wouldn't be able to provide this product at this low price.
SD Monitor: Yes, you can use it as an SD monitor. there are a few inputs you can use. I've tried the RGB HD input form the HVX and changed the HVX to 480p output and it worked. (the image wasn't as sharp) But it also has composite and S-video inputs. both which are SD resolution.
Price: The price is an introductory price. I think most will agree that at this price range this is a steal. I am reserving the right to increase the price at a later date. So get them before they go up in price. :)
USLatin,
that test is being administered on images taken by the camera. So they are reviewing the TIFFs or JPGs. You can't do that with the LCD screen. :(
I do own one of these:
http://www.calibration-direct.com/prodspydertv.html?gclid=CJXyiv73lpACFScXagodE3YR7A
so I'll see what kind of results I get by calibrating it to that. but I'm not sure it will give us a definite color reproduction chart for this monitor.
Hey maybe after some testing as to how to get the best results out of it you can ship the monitors pre-calibrated with the spider? After doing a few you might learn how to get the best out of it?
Or maybe all you have to do is get one dialed in just right and apply the settings to all? My guess is that there would be differences between the samples of hardware though, making it so each would be slightly different.
I don't think its necessary to calibrate each one before shipping. I will be testing them myself prior to shipping, but each input will be bringing different settings to the LCD. The best thing to do is to introduce the LCD to your setup, feed it bars and calibrate it.
That has yielded the best results for me. :)
ps: Thanks to those who have ordered so far. I've almost sold all units on my first batch and should be shipping those next week. The people on the next batch will have to wait 2-3 weeks prior to shipping.
Nice going, hope the whole warranty thing is easy and u can figure it out so u can crack these out without worries.
Unfortunately I am not sure if I'll make it to the meeting but it is no biggie since I am not in the marked for an on-board yet.
Hey, Luis
Really great spending some time with you at DV Expo.
I'll be mentioning the monitor in my Feb column in DV.
Ned
Sinarch,
Really interested in your monitor. I noticed it has a DVI input. This may be a crazy question, but could your monitor serve dual purpose by being a camera monitor and a production monitor for color correction using a MBP and FCP or Color? I've started paying more and more attention to my color correction lately and I've had a difficult time getting accuracy between what I see on my "calibrated" (with a SypderExpress) MBP LCD and your average home dvd player/television.
Hi There.
The MPB is not for colour correction! You can make things slightly more in tune with domestic TVS by tweaking the settings in the display to be cooler as this is more realistic.
