People have complained that Canon XH-A1 has very low levels when connected to a standard line device; you have to turn the audio level potentiometers all the way open to get a good signal. This has people worried as the conventional wisdom says you have to operate pots at the midrange for good results.
Maybe this behavior is not a fault but a feature: it makes setting up real easy!
I made some recording tests and found out that when feeding a signal from SD302 mixer and having the camera pots all the way open I got a perfect level match. Clipping level test signal from SD302 gave 0 dBFS peak levels on tape with no clipped samples!
Moreover, pink noise tests from a low noise mic gave -4 dBFS levels on tape when SD302 limiters started to kick in (set at +17 dBVU). Most amazing was the S/N ratio, pink noise and mic turned down the levels fell to -94 dBFS, which approaches the theoretical limits of 16 bit systems!
From now on I have no qualms using XH-A1 with line in and pots pointing south.
