because it's very dependent on what camera was underneath it. It might be 100 on an HVX, and if so, it'll be ISO 25 on an HV20. The Brevis itself doesn't have any manner of ISO associated with it. It's the adapter + camera combination, and even then especially with a Brevis it'll depend also on which ground glass you have installed.which rated the Brevis at ISO 100
Rating a camera at a certain ISO is a speculative prospect at best. For one thing, it all depends on what gamma curve you're using -- if you're talking about an HVX for example, HD Norm will give you a base ISO of 320, but CINE-D will be more like 250.
And you can't just say that:
They do? Never seen one on a set, never seen anyone try to do that...Gotcha...understood....I know its approximate, but people still light with 35mm adapters and a light meter
(okay, not strictly true, I think Macgregor brought out his light meter once to set a background light to a certain ratio to the key, but other than that, no, I don't remember the last time I saw a light meter on a video set, much less a video set using an adapter).
You'd be much, much, much, much, much better off to use a waveform monitor than a light meter when dealing with stuff like this. A light meter is okay for roughing in or setting ratios, but for actually setting exposure? Not so useful.
Why not use a 18% gray card and use it to find ISO? I do it all the time at film school and it works. I usually light the gray card until my in camera marker reads 40%... (40% because of video's ability to better represent the lower zones vs it's horrible upper zone ability where whites usually blow out much faster)
And because gamma settings and different scene files will have different ISO's, one just simply needs to have the settings on when one performs the ISO test!
As soon as cameras like RED become more prevalent, people will get back into light metering, because video isn't aways a WYSIWYG format like many believe it to be.
Video is exactly a WYSIWYG format. Red isn't a video camera, and neither is film, therefore your comments would apply to those. But with a properly-calibrated monitor, video is nothing *but* WYSIWYG.
And in reference to your curves, just make a curve chart. I have made a curve chart for the HVX scene file CineD, the Cinealta default, the Varicam Default, and two Cinelike (1&2) for the SDX. It's not hard.
So lets say I am working on a film and I have my scene file down before filming. I simply need to find the ISO by using an 18% gray card and exposing it at a certain f-stop to get a 40% reading on the marker. After which, without touching the fstop on camera, I will move the lights in toward the card (or just add more) every time I get exactly (to the tenth of) one stop more of light (on the card) I will write down the % the marker reads. Until I reach +100% I keep going. Same with below N (40%)
Here is a complete and made up sample of what a chart would then look like:
Stops %
+4 99+%
+3 90%
+2 82%
+1 65%
N 40%
-1 30%
-2 21%
-3 14%
-4 8%
-5 5%
And of course I now know the ISO of which to set the light meter.
As Barry did mention, Video sets are usually without light meters. A waveform monitor is a great way to look at exposure. But I find the main reason the lightmeter is dead on video sets is the inability for people to set and use them. Plus, (I'm not knocking anyone) the combined laziness of looking at a preview monitor to judge exposure has also plagued the use of the light meter. I for one am a strong believer in the zone system and spot metering.
So as you can see, I'm not using the gray card for anything but a control for the test. It's all based off of my personal exposure of skin tone for 40%. Now is skintone 18% gray? No. But I know that and everyone has different skin tones. Lighter then 18% gray card and darker then 18% gray card. So I find this a suitable way to find exactly what I need.
Feel free to respond if I am misinformed. I'm always open to new ideas.
