MattinSTL said:Any 21" 55w 4-pin (german style) compact flo tube should work. You can give yourself an upgrade just by trying a different tube next time.
MattinSTL said:I've played with a biax or two over the past year and a half... trust me there are about 10 choices of lamp that will work in your Flo-Light. If you want the highest lumens combined with highest CRI then you will get a Kino tube... if you want a tube that's a true 3200k or 5600k then you will get a Osram Studioline Biax... if you want to save money and get true 3200k or 5600k then you get GE Cinema Plus... if you want to save the most money then you get Dulux... this still doesn't cover half of your options.
Any tube that is 21" long, 55w, twin tube, and looks like this at the bottom will work. That is a german 4-pin. Flo-light uses the exact same sockets that I do... and so does Kino and Mole. It's a 2G11 socket.
I think I'm the only one who hates the 21" 55w 4-pin (german style) compact flo tubes. I think Diva Lights, or anything else using the 55w 4-pin tubes suck for location use.
The 3200k Kino and 3500k GE Biax tubes are slightly magenta. Dimming these bulbs only make the magenta worse. Kino says it doesn't show up on film - but if you are shooting video, trust me, it shows up.
If you are mixing tungsten and the Diva lights together, white balancing out the magenta cast doesn't help - taking out magenta by doing a white balance on the Biax bulbs will only make the tungsten heads look green. This is made worse if you are using a Panasonic camera, as the cinematrix modes boost red. You need to add some 1/8 to 1/4 plus green on the 55w 4-pin bulbs to correct the magenta cast.
The daylight (5500k bulbs) are pretty good actually - still not HMI quality, but still usable.
In terms of durability, the 55w 4-pin tubes are not safety coated - a *very* slight tap on the bulb and it shatters into a pile of glass. My grip and electric crew have broken 8 or so 55w bulbs this year alone.
I'd rather take a regular 2'x4 or 4'x4 kino select system (not the Kino fotoflo) anyday over a diva 400. The tubes are safety coated, you can use switches to do the same effect as dimming, the tubes can be removed to be taped directly to walls, the inside of (parked) cars, etc. And the 'tungsten' tubes don't have a magenta cast. Comes in a variety of colors - 2900k, 3200k, 5500k, green, blue, red, yellow, etc.
Tim
