snodart
a little more.....
Keep in mind that focal length DOES alter the actual DOF.
If I focus on a subject at 25 ft with a 50mm lens and then focus on the same subject from 25 ft with a 100mm lens, the actual DOF will be very different. At f/5 the DOF with the 50mm lens would be about 29 ft. At f/5 with the 100mm lens the DOF would be about 5.7 ft.
The problem with this of course is that the subject size within the frame is much different between the 50mm and 100mm lenses. With the 50mm we might have a medium shot while the 100mm might give us an extreme close-up.
Now if I place the 100mm lens 55 ft from the subject so that the subject size is comparable to the medium shot that we have with the 50mm lens, then my DOF is 29.6 ft (about the same DOF as the 50mm at 25ft).
In this case the DOF is technically close to being the same, but the apparent DOF in the final images will look very different. This difference in the apparent DOF between the two images is due to the fact that the degree of detail blur varies with the lens focal length. With the 50mm lens, that fact that the background is out-of-focus is less noticeable. With the 100mm lens though, we are seeing a magnified portion of the background... so the fact that it is out-of-focus is amplified.
So in the image above, the actual DOF might be very similar, but because the telephoto lens is only seeing a small portion of the background... it appears as though the telephoto shot has a much shorter DOF.
Focal length and camera-to-subject distance have a sort of balancing act going with each other when it comes to the actual DOF. As a general rule, if the f/stop and the subject's size within the frame remain constant, changes in focal length and camera-to-subject distance will not alter the DOF (at least not by very much). Focal length and camera-to-subject distance sort of cancel each other out (IF the subject framing remains the same). But again, the telephoto will give the appearance of a shorter DOF.
A telephoto can come in handy when you need the appearance of a shallow DOF, but don't want to risk loosing focus on the subject.
