Now that Premiere 3.1.0 supports native MXF reading and editing, I need to devise a workflow for getting my audio edits out to a professional DAW.
Now when you try and do an AAF export of your Premiere project, but you shot using the HVX as your audio recorder, you can't embed the audio. This is my #1 gripe about Premiere right now... it should just demux the audio into a temp WAV/AIFF file, embed it into the AAF then delete it. But rather Adobe chooses to ignore any additional AAF functionality since initially adding the export to the application in 1.5 (?)
Regardless, you can export an AAF and have it reference the original MXF data.
Has anybody had success in exporting an AAF of a Premiere project shot with HVX/P2 and having it be readable in ProTools or Nuendo?
Please don't suggest to use Audition/Soundbooth. Those are not professional DAWs and do not have the amount of features necessary to mix for a feature-length film. I need handles, and exporting each track from Premiere as WAV is not an adequate solution.
