plainman007
Yes David > The problem at my place is that the guys have a max of about 4 P2 cards and that seems like a no go situation. Plus its a lot of moving with long sequences of movement.
I never convert to AVI -- there's just no need, unless you also want to work with a program which can't read the MXFs or use Raylight (like After Effects, though I understand that's about to change, maybe on both counts).
You can rename the clips, but you'll have to rename the audio, too. Again, this is something I'd do in P2CMS.
I organize my P2 material by date of the shoot and by the order the cards are captured.
quote]
In the case of a large project (full feature), do you think it is best to keep all the P2 card contents in one big flder called "FOOTAGE" for ex? Or put them in sub folders under each scene folder?
I can see pluses and minuses in doing it either way. the second way you have yoru clips sorted on yoru hard drive by scene, might help in finding them faster outside of vegas. BUT, it might also make it harder to browse through misc footage because they are now scattered in many different locations.
How do you do it?
