jgastelb
Both lenses (28mm) are Canon FD lenses f2.8. And I have kept the aperture open the whole time with a paper clip attached.what mount is it? make sure youre apeture is open it could be stuck.
My Nikon 28mm works just fine with my old FE and new EX.
Have you heard from Letus about this? It does sound like you may have a defective adapter. Hien is usually pretty fast about resolving problems.
Strange enough, I have a 28mm Nikon f2.8 and I have the same issue (had the same issue with the M2 and the Brevis as well); so I've given up on using this lens. I did speak with Hien and he also suggested just zooming in past the left screen darkness, but my 35mm achieves the same FOV.
Mmmm...i just don't understand why the 50mm lens works and the 28mm doesn't....Doesn't make sense to me, since if this was a still camera, the lenses still need to focus on the same plane don't they?
I don't know if someone already asked this, but this are thing easily overlooked.
Is your lens made for a digital 35 mm still camera?
Digital lenses don't need to cover as mush area as the still film cameras.
Is your adapter perfectly perpendicular?
Is the lense flush against the mount? Its weird that it would off center like that. I also have a 28mm that works fine on any adapter i put it on.
This is the second one I got.
http://www.keh.com/OnLineStore/Prod...CC=&CCC=&BCL=&GBC=&GCC=&KW=canon 28mm fd lens
If you don't change anything you'll get the same results.
That is an economical lens. It is made for digital 35 that means that it doesn't cover the 36 mm X 2 mm required by the adaptor or a 35 mm film still camera.
Ask someone to lend you a lens made for a 12 MP full frame camera and see.
It seams to me that the problem is the lens, but what do I know.
Douglas and Jgastelb,
FD lenses cover the full 35mm frame. Canon discontinued the FD mount long before they ever even created a digital slr so there's no way that an FD lens could be designed for a reduced frame digital sensor.
You also seem to have a problem with the CCDs on your camera being off center. A lot of cameras have this problem. You can never tell with the normal lens because the rear projection of the normal lens is wide enough that you'll never notice it.
I hope this helps.
Simply put most of the new digital cameras are not full size 35 mm (36 mm X 24 mm). For this reason lens manufactures make inexpensive lenses that only work with the less expensive cameras (Revel etc.). When you use this lenses on cameras that have full 36 mm X 24 mm film plane (including 35 mm adaptors of any brand) they vignette. In other words they don't fill the whole screen.
I haven't kept up with photography for the past 15 years, but this much I know.
I can't know for sure in your case, but. You have 2 lenses that work fine and you have two equal lenses doing the same vignette. That points to the that particular 28 mm lens.
I hope this helps.
