Ugg. Haved to recapture my footage. Want to do it right this time!
DoubleIt
Ten million problems so I need to recapture six hours of footage. Horray.
Last time I had a bunch of errors in capture while capturing for 2:3:3:2 advance pull down removal in FCP 5.1.4.
When capturing 24pA footage in FCP 5.1.4 what is the exact correct method. As per the stickied post I do not see a checkbox that says 'remove advanced pulldown".
Do I want to use the capture preset (under capture/input while in log/capture) for advanced pulldown? Or do I capture in 29.97 and use media manager? Ugg! Real annoyed that I have to recapture so I just want to make sure everything is correct.
The way I captured before I was not able to view footage that was dragged onto the timeline without rendering first. This was insane and frustrating and possible to edit on.
Ok...
Let's figure out what you did first.
What was the EXACT settings of your capture settings used to capture the clips?
What is the frame rate of the clip you captured that is in your browser? You'll find that in one of the columns if you slide to the right.
Then... what is the timeline frame rate? Apple-Zero the sequence in your browser to find that info.
CaptM
