S
SeanEmer
Guest
You might look into something called Automatic Duck. It translates timelines from video editors into after effects, which might be helpful in your case.
As far as I know, there's no Automatic Duck plugin for Vegas to After Effects. Actually, I just checked now and there is none.... that's too bad... I wish there was...
Triple E Productions
Editing, Color Grading, Visual FX, Motion Graphics. Reasonable rates, AWARD WINNING work!
paul@triple-e-productions.net
www.triple-e-productions.net
Argh, nevermind then. I thought I had seen vegas on their site... it was probably Premiere.
I edit in Premiere, so importing into AE is a breeze and keeps the cuts exact.
If you are wanting to Color Correct in AE and can only import your small chunks as Quicktime movies you will still need to cut your Quicktime movie into separate shots to color correct them especially if your lighting changes and for consistency.
You can cut them up in AE no problem. I would color correct in 16 bit mode though. Once you are done color correcting and applying your final look to that section, I would recommend exporting back out to a TIFF sequence or some other lossless Image Sequence format, that way if you needed to change one small section you could just make your work area for that section and rerender the work area instead of the whole movie.
I did this with my full length feature.
Edited and created the final audio for each 10 minute chunk in Premiere. Brought the chunks into AE and color corrected, applied transitions, letterboxed and final film look, (always color correcting in 16 bit instead of 8 bit) then exported out to TIFF sequence. I did this for the entire movie. Then I reimported all the TIFF sequences back into AE (it treats each sequence as a movie) and placed them on the timeline back to back. I also placed the final audio for each chunck underneath it so they would sync correctly. Exported back out to MPEG2-DVD in 8 bit. I then imported the movie into Encore and burned to DVD with menus created in AE.
I used the workflow that Stu Maschwitz recommended in his book DV Rebel's guide and it worked like a charm and produced great results.
It's not Premiere cuz Premiere already interacts with After Effects. I was seriously considering switching from Vegas to Premiere because of this, but as of right now, I just can't.
Here's the link for the Automatic Duck After Effects import. It's Avid, Final Cut Pro, or a project from Apple's Motion.
http://www.automaticduck.com/products/piae/
Once again, too bad there isn't one for Vegas.... :thumbdown:thumbdown
Yeah, I meant Final Cut when I typed Premiere. I caught myself, but you caught me before I could edit my post, haha.
I've been an Avid editor for close to 4 years, so I sometimes get all the other programs mixed up...![]()
16 bit gives you more headroom, so to speak, avoids things like banding, posterizing, etc. If you want to be really brave you can CC in 32bit float which will react more like real light, i.e. you can work in stops and such.
http://prolost.blogspot.com/2006/02/linear-color-workflow-in-ae7-part-1.html
read all seven parts and you'll understand bit depth.
This info is gold.
I'm actually going to be learning AVID soon cuz that's where a lot of the higher paying jobs are. Do you like AVID? I'm assuming so cuz thats your NLE hehe. One thing I absolutely LOVE about AVID is the three window color corrector. That thing is awesome!
I thought that 32 bit was only for HDR images, and it wouldnt benefit DV (DVX100a) footage at all.
