Sorry, I don't have the DVX cam, still I think that the DVX will not be too heavy for this design:
Obviously, with simpler tripods this setup works for a certain leg length only, or you need to drill more mounting holes. For better tripods with bottom spreader this will work even better since the distance between legs does not change. You need to drill mounting holes right above the wheels or a bit outward to keep the frame straight when loaded with tripod and camera.
I chose 120 degrees between axles to simplify the design because I bolt the wheels directly to the PVC pipes, but frankly 90 degrees works better because the wheels hold the track better. For 90 degrees angle I would have had to use spacers between the wheels and the pipe.
About $15 dollars for pipe and tee connectors I think. The wheels are cheap, but the bearings are expensive. Ask your friends if they have skates they don't need.
See the article with pictures here: http://www.elurauser.com/articles/centi_dolly.jsp
There is also a quick and dirty how-to video: http://www.youtube.com/watch?v=I2C7W3AFVrQ
