Uneven anamorphic in the viewer and canvas
mattadamsapple
I've been able to start editing but I've run into a minor problem which I'm hoping is a simple fix. When I make an edit and it shows up in the canvas, there is a slight difference in the amount of black on the right and left when compared to the previous clip. Is there a setting I'm leaving out so this doesn't happen and all the edits in the canvas have the exact amount of black on the right/left/top/bottom??
Is this because I captured the footage in anamorphic??
it was shot at 480i 24p. When I click on the motion tab in the viewer window and center both points at 0 everything is perfectly aligned from viewer to canvas but I shouldn't have to center EVERY clip, right? Is there a setting that I'm missing that centers each clip?
Your footage is not anamorphic (16:9) so why are you using an anamorphic project?
There should be no bars on any side of the image and everything should be centered without input from you.
