siniarch
New WEB SITE: www.lsdsgn.com
for my new High Definition Monitor. for sale!!!!
Ok Guys,
So after 9-12 months of trying to put this thing together and being ignored, stalled, and manhandled by the LCD industry, I'm finally proud to mention that I've pretty much finished my LCD. (really wished I would have been able to get this thing out sooner)
Here are the specs.
LCD Panel:
Here are the first pictures. Please comment and ask questions if you would like.
Note the RGB connectors on top will be BNC and not RCA as those shown. I will fix this. I also need to add stickers to label things or possible do silk screened white letters.
Thank you.
Luis Sinibaldi
Ok Guys,
Here are the specs.
LCD Panel:
Features:
- High resolution
- Ultra-wide viewing angle
- High contrast
- Wide color gamut
- LVDS interface
General Specifications:
- Display area........................170.5mm (6.69") W x 127.9mm (5.06")
- Diagonal Size .....................213mm (8.4")
- Display Color.......................16,777,213 colors
- Pixels..................................1024 (h) x 786 (v)
- Contrast ratio......................500:1 (typ.)
- Viewing Angle......................Horizontal 85°R, 85°L. Vertical 85°T, 85°D.
- Polarizer Surface.............Antiglare
- Luminance.....................350 cd/m²
- (this is the panel with the regular inverter. I have a more powerful inverter, but no way of testing the actual brightness. Its definitely higher than 350 though)
- Backlight........................Edge light type: 4 cold cathode fluo.
- Power....................................12v
- Video Inputs..........................ARGB, DVI-D, Composite Video, S-Video, HD-Component (YPbPr), HD-SDI (optional w/1 or 2 channels)
- HD-COMPONENT PORT :Mode Resolution
480p/60 720x483576p/50 720x5761080p/30 1920x1080
720p/60 1280x720
720p/23.89 1280x720
720p/24 1280x720
720p/25 1280x720
720p/29.97 1280x720
720p/30 1280x720
1035i/30 1920x1035
1080i/50 1920x1080
1080i/50 1920x1080
1080i/29 1920x1080
1080i/30 1920x1080
1080p/25 1920x1080
- COMPOSITE, S-VIDEO
System Resolution
NTSC 720x480NTSC 4.43 720x480SECAM 720x576
PAL 720x576
PAL M 720x576
OTHER: - Picture in Picture
- Flip Horizontal, Flip Vertical, Rotate
- Picture: Brightness, Contrast, Saturation, Hue, Sharpness
- Aspect Size: 4:3, 16:9, 16:10, 2.35:1, 2:1, 1:1
- Custom sizing: Under-scan, Normal, Custom (you kind of can zoom in on w/ this setting)
- Blue Only (not sure if you can calibrate with this option, but its in the menu)
- Auto Picture, Auto Color (I set my bars from the camera and this calibrate the monitor pretty well. Really like this feature)
- Gama: 1.0/1.6/2.2
- OSD: position and time to remain on screen, transparency (for menu)
- Color temperatures: 5000k, 6500k, 8000k, 9300k, User
- Monochrome Mode: color, red mono, green mono, blue mono.
- size ......................8.5" wide x 6.625" tall x 2.5" deep
- weight...................3.2 lbs with the (1) HD-SDI option
- As of the new Bios Monitor can ZOOM 1:1 and beyond! (way beyond)
- It can also PAN when zoomed
- It can now FREEZE frame
- And will have a Hard Switch to not Drain Battery Power.
Thank you.
Luis Sinibaldi
