FCP to Color and back - Interlacing issue
electricpig
I've edited some longform FCP sequences in DVCPro50, anamorphic, progressive PAL.
Sent to Color, graded and sent back to FCP
It all arrives back to FCP as Field Dominance: Upper (Odd)
checking an XML Color export in a text editor shows: Lower (Even)
I've done a search and replace in the text editor and changed all occurances to: None
FCP ignores this on import, and seems to be screwing with the fields in general.
what's going on when I've gone nowhere near interlaced footage?
I can change these all manually inside FCP, but there's about 190 clips, and I've got 7 of these progs. As Field Dominance isn't an attribute I can't change all together.
Can anybody shed any light on this? V.frustrating
electricpig
streuth... Guess I'll change the field dominance by hand then in FCP, unless there's a way to do it globaly on all the clips in a timeline?
Too far down the line, and too much generated data already to do that with input clips.
Thanks for your help by the way.
