Hello every one, this is my first topic post and I've built a 35mm adapter.
Pretty much my adpater uses the spinning disc method, but instead of a spinning disc, i used the back part of a Jewel cd case, which seems frosted enough. The reason I used this particualer item is because I can't find any frosted CDs anywhere.
anyways I will hopefully have some pictures of my adapter up soon, and the footage seems to be ok while adjust the DOF of the lens.
I'm am using a Rikenon 50mm lens, and a macro lens on the other side. The whole systems is incased in a plastic box from Tandy with dimensions 110x140x30mm. The motor is from an old sony discman that I ripped apart, and runs on 2 AA batteries. PVC end caps were used as spacers and holders for some of the lenses.
moderate to minimal noise was heard form the adapter but still a buzzing sound.
pictures will be up hopefully later today.
http://www.flickr.com/photos/11985360@N06/1340448398/in/set-72157601895869856/
or
or
