majormorgan
Hiya, I know this has been discussed.
I'm about to buy this Marshall monitor for my HVX 1080P focussing needs. Can you guys who have it recommend it?
Here is a link to the product:
http://www.creativevideo.co.uk/public/view_item_cat.php?catalogue_number=mar_v-r70p-hda
1. Will the image be enough resolution to be able to focus correctly?
2. Also as I am using the SGPRO 35mm adaptor does the marshall have a flip image? The arm I have will hold the monitor only one way up unless it has mounts on top and bottom.
3. Does the component HD signal receive a 1080 from the HVX?
4. Also do you know if it also shows the focus assist zoom view the HVX finder displays?
5. The battery option is this an easy to buy and charge option? ITs a V mount battery plate? IS it a sony battery and are the chargers cheap?
Thanks in advance,
Richard Morgan
Thanks in advance,
Richard Morgan
