not able to view footage in monitor
scorsesefan
I am working in FCP 5.1.4 and I am hooked up to a field monitor via firewire to camcorder to monitor. After I have captured, I try to view footage(settings to external A/V, all frames) and all I will get is a still frame from the footage before I hit play and then it goes blank. I have tried refreshing A/V and I will get still frame again, then same problem. I am capturing to native HD and then transferring capture scratch files to xternal hard drive. Any suggestions?
-Thanks
p.s. I can view footage fine before capturing.
what camera are you trying to pass thru?
FYI: You can't use the HVX200 for HD pass thru monitoring.
Not sure about the other HDV cameras.
