(Err, need this to work for festival applications!)
I am having trouble exporting (via Compressor) a clean version of my short film. I've tried a number of things but it always ends up with jagged horizontal (interlaced?) lines in areas where there is motion in the frame.
Here's background info:
Shot on super-16mm. Telecined at Fotokem, where they delivered back on HDCAM and DVCAM (which I'm using for the edit). I think they laid it out at 29.97fps even though it was shot at 24fps.
The reason I think this is in IMAGE #1:
DVCAM timecode in UPPER left runs at 24fps.
DVCAM timecode in LOWER left runs at 30fps (or 29.97).
It looks fine in FCP in a 29.97 timeline as shown in IMAGE #2 (though when my editor originally put it into a 24fps timeline, it had this same line-blurring interlace-like problem).
When exported as a QT movie (to get feedback from a colleague), movie now has this line-blurring issue usually when there's any kind of movement as shown in IMAGE #3.
Settings for Compressor were h.264 LAN (bit rate dropped down to 1000), with framerate at 29.97 and keyframes every 15 frames (upped from every 150). Frame re-ordering is checked.
Subsequent export tests also left same problem. Trying switching lower/upper fields. Also tried exporting at 24fps in Compressor. Also tried placing it back in a 24fps timeline (which showed jagged horizontal lines even in FCP sequence) and then exporting via Compressor.
I need to be able to send out a clean copy for festivals! I would like to know what I'm doing wrong with export settings.
Thanks fellas,
Joshua
Thanks fellas,
Joshua
