brokenjack
I've made alot of my own gear, and I'd like to take it to the next level. I've heard mention of milling and CNC work. What decent benchtop stuff is out there, and how does one approach learning how to use the stuff.
brokenjack,
You might want to try out a local tech college and see about taking machining classes. It is a good place to start and many times you can have access to some pretty good equipment while you are learning. As for equipment, I'd suggest taking a look at it after the class(es). That said, check out www.homebuiltstabilizers.com There is a lot of good info there on equipment.
Shred, I don't think that will work with metal, and for the price he is much better off with the Taig Tools Micro Mill in my opinion.
I built a CNC earlier this year, i still have to make 3 small brackets before i can really use it though. I spent about $1100 and two weeks to build it.
I design it in cad and then use the G-Code generator and then run the G-Code in Mach 3.
Check this out
http://max-wilson.com/category/projects/cnc-machine/
"I've made alot of my own gear, and I'd like to take it to the next level. I've heard mention of milling and CNC work. What decent benchtop stuff is out there, and how does one approach learning how to use the stuff."
Start off with learning the machine manually, then all of the tooling first. This is not something to just jump into, there is alot of practice and reading involved (Gcode/CNC is a whole another animal).
Example
If your code is off by a few thousands and your machine crashes, it's nothing but blood or money. I couldn't tell you how many bits I've broke from just the littlest mistake and at $15.00 - $120.00 each bit this can add up. This is why I say learn everything manually first, believe me it will help you in the long run. Now they have simulator programs that help check your work/code for crashes, but these programs only help so much, it really comes down to experience.
If you do decide on a machine, definitely build an enclosure for it. That way if a tool or part breaks, you're somewhat protected from flying objects. I've come very close to almost loosing my hand, finger and an eye. Oh and WEAR EYE PROTECTION!When getting into metal working machines, it's not a toy. It's taking me almost two years to finally get a brief understanding of things.
Here are a few pictures of my CNC mill working on steel, pictures aren't best of quality (cheap camera), but you get the point.
Now it's kind of hard to see in these photos what happened. My girlfriend thought it'd be a great idea to take photos of my bloody hand just before she fixed them up (She's a nurse).
Here's the new machine I plan to purchase in the next month or so. If interested check out the packages, very well priced.
http://www.tormach.com/Product_PCNC_main.html
