Off courseDid you press the button down on the Mayflash?
Also, Zak said he had issues with the HV20 as well. I'll have pics up of m'self actually using this setup soon. Gotta wait for them to show up in me email.
I wonder if the HV20 just doesn't work with this at all.
Off course
But I've tested the HV20 with Mayflash on 5 other displays (3 CRT's, 1 TFT + TFT/HDTV) and none of them worked. All out of range...
To be precise HF 28.1kHz / VF 50.0Hz
That's something most monitors don't support... and I've looked for the display specs of the Hitachi screen inside (Hitachi TX20D16VM2BAA), it says the following:
HF Typical 31.6 kHz / Max 39.2 kHz
VF Typical 60 Hz / Max 75 Hz
Also, I've tried to hook up my component DVD player to my HDTV using the Mayflash and the VGA-in on my HDTV, nothing, same for DVD->Mayflash->Lilliput
That's probably because it's all PAL and the Mayflash only supports 480p, 720p, 1080i, and 1080p and no 576p.
But back to the point...
"1080i/50Hz has a horizontal scan frequency of 28.1kHz, while 1080i/60Hz has a horizontal scan frequency of 33.6kHz"
Monitors usually don't support HF of below 30/31kHz
Maybe all the problems are only due to the PAL frequency?
I guess you have an NTSC HV20? Are you running it in 1080i component out?Thanks for the info ZAK,I had ordered a mayflash and it came in last night. I hooked it up and the image looks great. I'm not getting any ghosting that I can see, but I have no color bars to work with as the HV20 can't generate any. Maybe I'm blind too![]()
Never thought about that! But they're a little small for that, right?
