bvalente
DVXuser Sponsor
Okay folks, some of you have been interested in whether the new ikan v8000 hd monitor is any good. My box just arrived about 30 minutes ago, so here's a "first impressions" post.
Box/packaging: nothing to write home about, but solid.
Comes with: the v8000 monitor, a knuckle mount for the top of your camera (again, nothing to write home about, but gets the job done), power supply adapter, and wireless remote. Doesn't appear to come with any documentation, but the menus within the monitor are pretty straightforward.
For my purposes, I bypassed the knuckle and hooked it directly to my Redrock M2/HVX setup using my noga arm. Simple and painless setup.
Observations:
The ikan v8000 is an 8" on-camera monitor, vs. the marshall 7" monitor. It is also much lighter than the marshall owing to a plastic case that, while perhaps not as robust as metal, is certainly much easier handling for on-camera applications. Let's face it, the marshall is a rack mount monitor, and it's really great. Just a bit heavy and awkward on the camera. the v8000 doesn't strain my noga arm anywhere near what the marshall has been doing. Easy to move and adjust and then just tighten up. I would highly recommend a noga (isreali) arm for this monitor. 8" is great, but it's pretty big
The v8000 finally provides component in AND out, so you can put it inline with other monitoring solutions. nice. This is in addition to s-video and BNC in/out connectors as well. Nice!
It does not have internal flip, but mounted upside down works just fine.
It also has a panasonic battery mount, which is a nice option instead of the marshall v-mount battery (which adds considerable weight and strain to an on-camera monitor). (note: I have to double-check if it's a panasonic battery mount or other small battery mount.)
Image quality: While I didn't have a chance to put it side by side with the marshall (yet), I found the image sufficiently high resolution good enough for both framing and focus in HD.
Viewing angle: One of the drawbacks of earlier ikan monitors seemed to be a relatively narrow angle of view - a few degrees left or right of the monitor, and it disappeared. With the v8000 the viewing angle seems to be considerably larger: good news for ACs and focus pullers.
adjustments: solid on-screen menus for birghtness, contrast, and color balance. Would have been nice if some of these were knobs to make adjustments quick.
Questionable stuff: this category should be thought of as "haven't had enough time to figure it out yet, but...." Appears to have a "blue mode" but couldn't get that working. Has several options for color modes (labeled mytseriously 0-5), but couldnt' figure out what they did.
Overall, I'm pretty impressed. I didn't want to get my hopes up about a $750 monitor that had all the image benefits of a marshall but the lightweight form factor of a panasonic. So far, it's my monitor of choice for on-camera HD focus and framing.
Observations:
