mvb
DVXuser Sponsor
EDIT:
Ok.... here are the benches with P2 drivers installed, same setup, EDIT same clip though:
(BTW I am only testing MXFs)
Blue ... I got 18fps again... CPU hit 69% and 93%
Green ... still have to fix mine
Yellow... 30% to 50%
The Blue and Yellow modes do not use the P2 Viewer components so of course there is no change.
By the way you need to install the P2 Viewer, not the P2 drivers.
Once you do the Green mode should start working.
The Green mode will give you about the same loading as Yellow, but with
full resolution.
