Dennis Wood
DVXuser Sponsor
We've finally got all the bits and pieces in for our latest carbon fibre rails systems to support the Brevis35, upcoming flip module and follow focus. The rails systems are available in 30cm, 45cm and 60cm lengths. The carbon is made to our specifications with a very heavy wall, and is likely the sturdiest 15mm available anywhere.
These rails are versatile enough to provide support for virtually every setup out there, featuring shimless height adjustment. Small cams like the HV20 can be mounted inverted with the addition of a short riser tube.
A quick pic of the XH-A1 on the 30cm versions: (rig exactly as shown with XH-A1, Brevis35 HD, Canon FD 50mm f1.4 lens, Mattebox with one 4x4 glass filter loaded = 10lbs, 1 oz.)
