I'm going to try this - just for fun. Keep you informed. Any recommendations for ballast and 150W light ?
To be technically correct, if you were going to attempt this, you should use a beefier R7XS socket than the R7S halogen that's already there. That's an HID version which can take the higher starting voltage pulse. You would use this with the 150w RX7S metal halide double ended bulbs, like the one I used in my fresnel project in the article in my blog. The only problem you may run into is the distance between the sockets is a bit more than the halogen R7S bulbs that normally go in there
