smithy said:it isn't a joke...lights...when made correctly IE using photoflood and are positioned using 3pt lighting is very effective at a minimum cost. There are many that argue that you have to have pars or Lowels.. or arris to get the effect. Well that is not true...if you are educated in being a gaffer then you know your limitations. Bottom line is if you know how to light with the equipment you have the you will be 10x better than a rich person to buy all equipment without research to back their goals.
Policar said:Not really. Certainly, a painting by a good painter with bad brushes would be better than a painting by a bad painter with good brushes...but given good brushes, the good painter will not only work better and with more nuance, but also FASTER. Much faster--and more intuitively. The same goes for lights.
Let's say I want to make my key light a bit dimmer but can't move it further back. With fresnels I can slide in a scrim, adjust the beam from spot to flood, etc. In a few seconds. And then I can adjust to perfection.
With home depot lights? I could use a dimmer. Oh, but that creates a hissing sound and changes color temperature. I could switch the light out for another light, but that takes a while and is imprecise. I could use an ND filter, but, lacking barn doors, where do I put it so that it doesn't melt? How do I make sure I use just the right amount when there are only a few strengths? And then I want to adjust it to get it perfect...and this will take a while. Generally, too long.
And that's JUST to get the right AMOUNT of light, let alone color, quality, etc.
Want your light relatively high up? With fresnels, use a 12 foot stand with sandbags. Or cieling scissors. Or clamps.
Home depot light high up? Sorry, the stand only goes to 5 feet.
With a decent fresnel I can control the beam from flood to spot, which is useful for dimming as shaping light. I get rotatable barn doors, I can use softboxes with speed rings and good light stands and clamps, I get a nicer quality of light (3200k versus 2800k and with that pretty fresnel look rather than a harsh open face look), etc. etc. Filters are easier to attach, too. And the lights are generally more efficient.
Can you light well with home depot lights? Possibly, but it takes forever. Time is money, and renting a decent light kit (or buying lowells at the very least) is very, very worth it.
That said, those 70 watt pars you get at home depot for $8 coupled with the $6 cones are my secret weapon and china lanterns are a pretty great instrument, too. Even work lights can be bounced effectively, but a lowel DP light isn't much more expensive and is considerably better. Film lights may be overpriced, but they're still usually worth it. And used moles go for pretty cheap, too.
Policar said:That works to a point, but photofloods aren't home depot lights.
Also, diffusion is a poor dimmer because it changes the quality of light quite significantly. But if you're using soft light, it's a good solution.
Ralph Oshiro said:Now all we need is a Key Grip from Paramount to write the companion manual, "How to Make any Piece of Grip Equipment from Stuff at Home Depot."
