totalfilmmaker
I didn't see any on thier site so I don't know. I'm sure if you called them they could tell you.
filmat11 said:I have spoken to Imagewest about my order, and it appears that it was misplaced. My cashiers check was never cashed, and my order will be sent out soon after this weekend. I added an Alzo light onto my order, in addition to my 1k fresnel.
Since I'm on the road quite a bit, checking to see if my check was cashed was always ackward, as I would return home from a gig, to leave again, and each time forgetting to call the bank, even though I had my copy of the check stub on file.
The owner of the store is very nice and accommodating to speak to, and is very proud of his Bluelines. I too will give my opinion about this light when I see it. Now, sooner than later. Thank God...
epicedium said:Fixtures don't "overpower" bulbs ... When you're talking tungsten, really all the fixtures do is wire the bulb to the mains (120/240v) and physically house and focus it. Bulbs "draw" the current that they are designed to draw, so the only questions are, a) does the bulb physically fit the fixture, and b) can the fixture handle the current and temperature requirements of the bulb. Since you're talking a smaller wattage bulb then clearly temperature is no problem, so then as long as it 'fits' then it'll work.
Aram Bauman said:The only problem we had were both 650s had a flicker problem toward the end of the night where they would seem to sizzle a little and go dark here and there.
