mvb
DVXuser Sponsor
Dabhand Digital Media said:Hi Killfilm.
Can you answer these questions.
1. Are your project settings exactly set up right for 720p? By that I mean in the projects table have you selected the (progressive mode) and the corect aspect in the dropdown to 1.0000 (SQUARE)?
2. How many fps are you getting in Preview mode quality as fullscreen playback with both ( color correction with slight desaturated ) and colour curves, crushing some backs...Does it hole a full 25fps (PAL or 29 (NTSC)
3. Are you using the Raylight plug in for MXF at the best quality? If not then what setting do you have it at? Apparently the new beta version is better for playback as it uses DX9 addressing within windows.
Thanks in advance.
DDM
The Raylight benchmarks can be found here
http://dvfilm.com/raylight/raylightSpeed.htm
3.0 was released today, it's no longer a Beta.
