I took advantage of the sales at NAB to get a Petrol PEGZ-2 bag. Can't quite figure out how to make it work. In brief:
It appears the Tascam HD-P2 needs to be in the outer pocket so there's easy access to the top panel.
However, this means that the cables into each side (mixer in on one side, timecode on the other) interfere with the sides of the case. I can barely fit straight Neutrik XLRs in, but I'm not comfortable with the resulting sharp bend in the cable against the side of the case.
A jumper cable with a right-angle MALE connector would fix the problem, but all I find on Trew (and others) are short cables with right-angle FEMALE connectors. I suppose I can make my own short jumper cable...
Any suggestions? How do you folks set this up?
