Edius 4 and TitleMotion problem, help!
FoxAdriano
Hi, I use Edius NX for HDV and Edius 4: I have a new PC but when I try to open TitleMotion jams and I have to shut down my PC. I have unistalled it and installed again but I have the same problem. I cannot use TitleMotion 5.1.
Before to install TitleMotion I have installed "Microsoft .NET Framework 3.0". Will be it the problem?
.NET Framework 3.0 shouldn't cause problems but you may want to try uninstalling it to see.
Do you have the TitleMotion Pro for Canopus installed, or a different version of TitleMotion?
Yes I have TitleMotion Pro for Canopus installed. I have the original CD from Canopus (with Edius 4).
I have problems with 2D transitions.
I have Edius NX carc, Edius 4 and Ati X1950XT 256MB GDDR3 Video card with the latest driver. When I add a 2D transition on the toolbar I see a green vertical line I don't see the transition effect between the images.
Why please? Have I format my Sata HD? I have Win XP Pro.
It doesn't work.
In my Edius 4 every transition works in realtime. No problem. Buth Edius doesn't see some transitions only (aroud 10). With hardest transitios it works fine but with different transitions, after having added the transition between two clips, I don't see the transitions even if it there is physically.
If I make rendering I have the same problems.
I thank you of your help.
