Still good for you, bro!JasonFox said:I actually have an LCD with s-video in and it's working okay with my DVX. Not very bright though.
Cool Lights said:Do they also suck because of the small cell size? Do people prefer a 1" x 1" type or is the 1/2" x 1/2" x 1/2" thick cell size (like home depot type) good too for other uses if they come in black? I'm making egg crates now for sale as an accessory and the 1/2" cell type seems to be very common. You don't see the larger cell sizes on pro fluorescent fixtures that often from the survey I took. In fact the 1" eggcrates are usually always fabric and on a softbox of some kind. Would the 1" cell size be better for a flo?
MattinSTL said:Even though the Kino stuff is silver it still controls spill better then you'd expect... those eggcrates are parabolic cross-section. A normal fabric eggcrate is simply blocking light at a 90 degree angle... but the DEPTH of a fabric eggcrate is what gives so much control.
The Kino egg crate is made from the same insert you see in an overhead 2x4 office flo light... in a drop ceiling. If you take that thing out you can even see how it's been cut from a larger piece.
The best source for this material is Scientific Lighting Products<click that.
I've experimented with a crap-ton of this material in all types. One thing that you will find about that eggcrate is that it soaks up light... if you flip it over you'll see that you're actually blocking up to about 60% of the actual light transmission.
There is an ultra thin blade aluminum eggcrate that passes much more (I've used it and I like it)... but you really need to double stack it for an effective light spill control. You won't find any eggcrate that's more then about .5" thick (unless you get big square openings then you can get 1" deep)... The stuff comes in straight blade and parabolic so you can still tweek the results.
The best way to cut it is with a good bandsaw that's got a sharp blade... another option would be a really high tooth-count carbide blade in a table saw... but if you do it like that then finger retention is your own responsibility.
Anyway... roam around that site. You can find the exact product that Kino uses there... plus some better alternatives. For the record... a 2x4 piece of the specular silver that Kino uses costs something like $30-40(ish)... and the aluminum bladed stuff is $50+
Still... if you're into DIY then this could be a really cool source for you.
bilgami said:how about one of these http://www.optexint.com/sales/easyrig.html id love to make one of these.
