I am working on a short that we'll try to enter on film festivals. I want to use Vegas but now I am thinking that it might not be possible... As far as I remember Vegas doesn't support 10-bit and only uses 8-bit... right? But if Vegas is good enough for the HVX's output of DVCpro HD at 4:2:2 then there is nothing else to worry about right?
I read about upping the project to 10-bit, CC'ing in AE and then putting it back down to 8-bit... is that easy? Worth it?
I am such a noob that I am not even sure I know what that means... but it seems it might be a problem when trying to render a 720p for a big screen...
Should I consider 1080i instead of 720p? I understand you get more horizontal resolution, but you have more temporal resolution with the Progressive frames of 720... How does the 1080i de-interlacing work? How does it look after the process?
